Air baked clear coat.
Very very durable and uv resistant.
Able to wet sand and polish in 7-15 minutes… WOW!!!
I use this product on everything that has a show finish. It also works great if there is a small ammount of print on the surface. One heavy coat. Block sand. Spray again. Done.
FYI you can use normal reducer (medium, fast, and slow) with it as well but generally I stick with the kit sold at sherwin williams.
Check it out next time you want to go experimenting…
This clear can build to the point that it looks like gel coat.
I hope this product comes in handy for some one as it has for me.
