Hi Everybody
I need to test a sandwich laminate/coupons for shear stress. Has anybody some pictures or hints about a homemade test setup?
Hi Everybody
There was a DIY test setup explained in an issue of Professional Boatbuilder. (www.proboat.com). Somewhere in issue 80-100 or so. Unfortunately I tossed all of them during my last move.
I am thinking about buying all back issues (available on USB)
https://dl.dropbox.com/u/32251231/C393.pdf
https://dl.dropbox.com/u/32251231/C273.pdf
There are some sandwich shear ASTM tests, maybe that will help
Thanks a lot for the pdfs.
According to this thesis one could test a laminate for shear in the same way one would test for tension with the only difference that the fibers should be aligned at ±45º. Would you say thats ok?
If i test a laminate without core for shear, I should afterwards select a core that has more shear strength that targeted.
I can not say if that would work. I do not think that just by doing a tension test on 45deg samples, that would equal bending shear. You have to worry about the faces being in both tension and compression during a bend.
You need to be more specific on which shear properties you are trying to measure: in-plane (xy plane), out-of-plane (xz or yz plane) where the x and y directions are your 0 and 90 fiber directions and the z direction is the thickness of the laminate. in-plane shear properties of a single skin laminate can be measured using the +/-45 tensile test.
