We have a interesting scenario:confused:.
We have a kayak shaft paddle shaft light weight, high stresses made by a company who wraps either glass, carbon all pre pregs or a combination of all around a mandrel, tapes it then cures it in a oven.
We found out if shaft comes out cured of the oven and has blemishes or faults like not consolidated properly etc , firstly that is a indication the shrink tape did not do its job so its already starting the second process with a questionable product , instead of binning it they hand sand it down which has issues of how much have you sanded in places and not others and then add a few more layers, wrap it, oven cure it.
My opinion is when the resin in pre-preg âmeltsâ during the cure process it links from the mandrel side to the outer side as sort of one molecular unit.
To me if you then add a second layer which equates to re-joining it in a second stage after the first has had a full cure process it can never have the same properties as if it were done in one stage as your molecular link is not the same, they say it is as it re-melts the first layer again, I donât see (know) this is not the case as its cured resin not hot melt glue.
What is the opinion of those out there, is doing it twice above as strong or not, will it have more a chance of burst delaminating under bending pressures as we have found a few shafts that âburstâ for no real reason and suspect this may be the reason?
Thanking in advance for replies.
