Sorry for the numerous questions (I did do a search, honest), but here goes;
Does the cost of vacuum bagging & post curing materials (inc. pump, air compressor, heating elements etc…) outweigh its advantages for a small business/workshop setup compared to wet lay up and room temp curing? Or can it be answered by asking ‘how good do you want the parts to turn out?’
When doing vacuum bagging, how do you stop the bottom of the bag from getting sucked up into the valve?
If you go the post cure route with vacuum bagging, do you have to keep the vacuum pump on the whole time during the heat cycle, or is it sufficient to remove all the air and then just heat it up with no further pump suction?
Can more than 1 part be vacuum bagged at a time?
Can peel ply or that perforated plastic be used more than once? I hate the thought of throwing lots of plastic away and having it just sit in a landfill not being biodegradable.
Are there any re-usable vacuum bags? Again, making reference to helping the environment.
Once again, sorry for asking all those but I couldn’t think of a better/more friendly place to ask them. This forum is a dream!
Many thanks,
Kyle.
