seran wrap...
Before I spend an hour doing a test, wondering if anyone has experimented with resin on seran wrap. I am assuming that PER will melt it so i plan to use epoxy. Any info would be great!
it will melt it if you lay up too hot of a resin mix. But if you use it to just hold down wetted out cloth then it works just fine, pull it off when the resin is still tacky though so you can use subsequent layers :wink:
