Canyon,
Basically I agree with what the others are saying, print onto paper, cut the paper to shape and stick to your wooden ribs and cutt out.
two other ways that I have used both in the past, first take section screen shots on your computer then using a overhead projector shine onto your wood, draw around the outline then cut.
Or my current favoured method is to take a screen shot, convert this image to a vector file then using a sticker cutting plotter you an end up with a vinyl sticker you can put onto your wood then cut out. I now prefer this method as you wont loose and details as you could by cutting your pattern by hand, That and the fact that I have a sticker cutter my self that can cutt upto 900mm tall. Im sure your college will have one of these in some department somewhere.
Use a jig saw to cut the ribs out, sand down to your final line.
Dont forget to ruduce the size of your ribs to allow for the thickness of your fibre glass/filler and whatever else is needed to finish your plug otherwise it will end up oversize.
