I have a construction question many of you likely have experience in. I’ve made hoods and other parts in the past with these two methods:
infused the skin, put the core on top and did a regular wet-bag layup…not the best method and its not
Infused the top skin, infused the bottom skin, and ‘glued’ them together by using a filled mix of the infusion resin. While I haven’t had any failures with this yet, the infusion resin is NOT an adhesive.
Here’s the question:
If I’m secondary bonding a hood skin with a lower skeleton (or if i’m bonding wing skins to one another and the spars), what is the adhesive of choice? Should I use a polyurethane adhesive like Permabond or one of the Hysol epoxies? Any recommendations?
