Hello,
I am making an unpainted cf air intake for my motorcycle. It is cosmetic so I am not bothered by extra weight. I made a male mold from styrofoam and covered it with bondo to smooth it out. I want to overlay cf and then pour acetone inside to eat out the foam.
I would make this part in 2 pieces but the hole (air intake) in front is too small to be able to get inside to bond the pieces together. I will try a 2 piece part in the future.
My questions are:
How many layers of cf do I need?
Should I use any chopped mat and/or fiberglass first?
If I use 2 layers of cf, do I need to paint it black first so that the bondo does not show?
Any suggestions on how to cut the pieces of fabric to lay it up? I was thinking of 1 piece on the bottom and hopefully overlap that with one large piece on the 2 sides.
ANY other suggestions are welcome. I already screwed one up!
Thanks,
Chris
I can’t help it i’m a bike nut!
