Hi all,
Ive got a couple of moulds which I need to put in some access point on the back to assist with demoulding. Just parts with some tight radius and angles that don’t lock the part in but do make it impossible to get anything between the part and the mould to break the surface tension.
I toyed with the idea of bonding in a fitting to inject water or air in, but I think the simplest way is to just drill a hole and then bond a nut to the back so I can use a bolt to push against the part. There’s a few sections on these moulds that get cut out of the final part, so I should be able to get away without any cosmetic defects.
My question though, is how do I seal these holes on the mould surface? I will be infusing these parts, so I need a 100% seal. The easiest way that I have thought of is to make a ring of bagging tape around the hole and then put a piece of bagging film over it. Is there an easier/better solution?
