So i’m trying to cut cost on my consumables so im looking into “envelope bagging” which I just discovered. However, through my search on this forum, and google, I came up empty handed…
right now im attempting it with 20ga clear vinyl from joanns fabric… i just pulled vacuum and the nylon cracked at the inlet connector that sits over the spiral wrap… I’m having a hard time believing the Vinyl stretches 400% unless there is a drastic difference in the vinyl im using…
I’m about to try out othe nylon bag tubes from acp
https://www.acpsales.com/Nylon-Vacuum-Bag-Tubes.html
Is this reusable?
Can someone help explain this process to me?
are you still using spiral wrap?
what kind of connectors are you using for inlet/outlet?
Should i switch to a flat (washer like connectors to avoid breaking the bag?)and a manifold of 2-3 layers of resin flo instead of the spiral wrap?
any help would be really greatly appraciated. Pictures would be GREAT (im very visual). Thanks in advanced
