First off my project is with a console piece laminated in CF. When sanding in between layers is it necessary to go to the finer grits(1000, 1500, etc.)? The resin I have is self leveling. Does that matter? Will it fill the scratches if I use just 440 grit wet? Sorry for the noob question but I’m still learning composites. :oops: Also where can you go to buy finer grit sandpaper without going online? I’ve been to Wal-Mart and Lowe’s(which have the most variety) but they didn’t have any grit that high.
-This is an awesome forum, I’ve read about every topic in here and have learned quite a bit.
