Dear inmates,
A sort introduction is that I am mechanical engineer who has a little knowledge as far as composites is concerned but I am a quick learner and I can add to the other thread’s knowledge pool
Off to the main topic…
I am trying to make a mold similar to that that you see on the two pics. One male and one female part. I have only worked with vacuum bag systems before but very very briefly so this process with the mold is completely new to me. Excuse my ignorance… :eek:
Try as I might I could not find enough information for the RTM method. There is info in RTM light but it is not the same…
The part will be like an open box so I would like to ask all the people here if you could help me with the following.
I have seen that I need to put the inlet in the middle of the part in order to help with the air moving toward the highest point (the sides). But what about the vacuum line? Where does it need to be ?
The other thing that I would like to ask is about the edges of the box. I would like of be able to create them in the compression mold (made of Aluminium) so I avoid the trimming. Would that be possible ?
I need to bolt the box on to a steel structure. I have seen metal rivets, sandwich plates… the lot. Which one in your opinion would be the best? Would it be better to embed aluminium into the CF matrix or make a mechanical connection afterwards?
Many thanks,
D.
