How many layers of cf ( total thickness in inches or mm) would you make a cosmetic roof cap for a car? Also what materials would i use to make up the thickness of the laminate if i mold off the car?
Heat up some kind of sheet plastic like acrylic or abs with a heat gun to the shape of the roof then mold directly off that ? What type of plastic can be shaped with low temperature heat and then be molded off of? PE sheet?
3m does make a low surface energy transfer tape FOR PP/PE plastics…might work it you build up a structure in the back, or even a thicker layer of HDPE.
