My Robinair 15500 vacuum pump (two stage rotary vane) is only pulling down to 29" hg, according to 3 different analog gauges (albeit of the same manufacture), whether the gauge is connected to my vacuum plumbing or directly to the pump through a barb (but hey, I guess that means at least my vacuum plumbing is good…)
Is this too low for infusion? Is the pump toast now? I originally did have a leak in my vacuum plumbing and the pump probably has 50 hours of running at 28" with a leak (continuous oil misting) before it was found and plugged.
I’m really bad at converting units of vacuum pressure, but according to this chart (http://www.engineeringtoolbox.com/vacuum-converter-d_460.html) 29" is only 20,000 micron (20mbar?). Is that correct? Should I buy another pump for my infusion purposes?
I also have a Robinair 15310, which is a single stage pump (clarification on that would be appreciated too - I’ve heard some people say that multiple stages doesn’t actually improve achievable vacuum level, but rather just makes for a higher cfm…anyone know what’s up?) This single stage has seen better operating conditions since it’s never been exposed to a leak and only operates out of spec for a minute at a time while the degassing chamber is airing out. However, this guy only pulls down to 28.5" on my analog gauge.
I’m asking these questions because I have a pin hole problem that I’ve really not been able to solve.
nothing wrong with your pump.
