I’ve been working on several rifle stock plugs for what seems to be an eternity now. To date I have two plugs nearly ready for molding, and a number of plugs in process, and two working prototypes. For simplicity I used Rustoleum rattle can primer initially, but soon discovered its way to porous to achieve a class A finish. Had no problems with release though on a test plug and mold finished in rattle can primer using Partall #2 wax and PVA. Everything released fine without pulling up the primer. Next, bought some Duratec surface primer and shot it over a test piece previously shot with rattle can stuff (I know this isn’t recommended) and it laid down OK, no apparent reaction with the exception of a few pinholes, but the thickness of the Duratec obliterated a texture detail I applied on the forearm and the grip. The texture is very subtle, and after trying numerous techniques I finally got exactly what I want, so I’m not willing to change this. I’ve heard of some that thin Duratec, and I did cut it with 10% laquer thinner on my first go at it, but it still went down way to heavy for my liking. Can you cut it more, or should I try another product to retain the detail of my texture? Is it even possible to lay this stuff down without orange peel?
I know Adam at wyowindworks uses PPG automotive paint but I don’t remember what it is or his process.
Thanks in advance,I love this forum!
Jon
