T92 SealX appear a great product, I think that only absorb 200g/m2 or less per side vs 500g/m2 (correct approximation?) for standard foams. However It appear difficult to found for my, probably I never have acces to this foam, (I’m amateur level).
Then.
Could higher density to make lighter parts by a lower resin absortion in the foam?
Maybe, Could I use an adhesive film with a preimpregned cloth layer (50g/m2) with resin epoxy (estructural adhesive)?
I should make infusion before this layer will be cured fully, for assure a good adhesion between this layer and infused layers.
