After talking to some guys I wanted to check with the forum about what I was told. A few of my parts have been turning redish brown when they are post cured in the oven. I am using a high temp epoxy, mixing well (or so I thought), and using a grams scale to measure weight.
I talked to some composite guys and they told me the reason the parts are turning red is because of improper mixing or improper amount of hardener.
Does this sound right?
I mix the resin for about 5 min in a cup and sometimes heat it with a heat gun (apparently a no-no). Everything is stop on with mixture weights as well. Is there anything wrong with this technique?
