Resin turning cloudy
Need help,after the third attempt same problem on the pump side when clamped off resin turns cloudy and in the laminate where bridging accur,resin is cloudy,I have bought new material just in case moisture is in there resin is new tempreture is ok,on the resin inlet side resin is crystal clear.driving me crazy and money.
Which process do you use?
Sorry for late response resin infusion,I have been using spray tak may be to heavy could this cause the problem.
I have done the part the fourth time today without the spray tack,won’t no till morning if there is any difference,I will no straight away because pump side where I have clamped resin off will be cloudy.
