Im working on a project for a lab class Im taking at school that involves using a cardboard core hotcoated with poly resin and then covered with two ply fiberglass on each side as well as two ply carbon fiber. (Fairly heavy bidirectional, dont have the exact info with me at work though)
Due to time constraints and a couple others reasons I wont go into, I wasnt able to put it under vacuum/in the oven and had to do it as just a room temp cure/wet lay up. For the most part it came out great, but theres two spots on one side which are clearly resin starved and on the other side, its resin rich in a few spots.
This project doesn’t need to be load bearing, more or less it just needs to look good, so what Im wondering is can I coat the side that’s resin starved with more resin, let it cure, and maybe end up with a decent surface? Likewise, could I recoat the resin rich side and try to even out the surface?
Also, Is there also a clear coat that would work well in giving a nice finish? Id ask my professor, but hes out of town until mid next week.
