Hi everyone, I am looking for some advice with my layups.
I issue that I am having is porosity/insufficient consolidation of resin to tool face.
This is an intermittent issue, sometimes it comes out fine, sometimes it does not. I understand that there are many different factors that will affect this such as work environment, resin systems, process, vacuum etc, but I feel that my issue is something very specific.
I have tried many different variations of layups including IMCs (does not help because then bubbles will appear behind this surface coat), different vacuum levels, over saturating the fabric, pre impregnating the fabric etc.
This is my basic process sans IMC:
Resin system: Aeropoxy 2032 with 3663 hardener
Carbon fiber – have used a variety of weights from 5.8 – 7.2oz if I recall correctly
Schedule:
0/90
45
0/90
Surface coat – have done with and without -
Layer 1, add resin, stipple with brush, resin rolled until full saturated -
Layer 2 - As previous layer -
Layer 3 - As previous layer, ensure full saturation -
Peel ply – have done with and without -
Perforated release film all over -
Breather – have done with single layer, and multiple -
Vacuum (max 24.5 from my Gast) – have done scenarios with max vacuum from the get go, have done with a bleeder and held at around 10inches (full layup) and also done low vacuum until gel, then max. -
Bag has always been good, I do leak checks.
Some layups I have completely oversaturated the material to a point where my breather is fully saturated.
Other times I have tried to calculate exactly how much I need according to material used.
My results vary, and they does seem to coordinate with any changed I do. Ex, completely over saturating will come out the same as lower resin content etc.
I am stumped as to why I still have such a high failure rate. Especially when I see the same process done on videos, and in books and the parts come out with a smooth surface.
Some options that I am thinking of trying:
-Slightly oversaturated mix and solid release film
- No breather – don’t really want to do this, I’m afraid the weave will distort
Do you think it can be my resin system?
Any ideas and test suggestions are much appreciated.
I am honestly at a point where I feel that my issue is so small, that I just have to fine tune or change something in my process.
Also don’t want to go the infusion route or non-vacuum bag for this piece due to design of mould/part.
Thanks friends, all the best.
