resin remover
I would like to know about the best cured resin removerin market for effective use on metallic tools for prepreg component
regards,
Raghavendra
Fire is all that really works 100% of the time.
Hard work and technique.
1: make sure your mold is well released.
2: depending on where the resin build up is, and your mold metal, plastic and metal scrapers work well.
3: again, depending on your mold, you might be able to get away with a light sanding, being careful not to got into the metal too much.
4: dry ice blasting is another good cleaner, and it does NOT hurt the mold. I think it’s pressure blasting with dry ice pellets. Like sand blasting, but not destructive.
Thank you riff42 for the details
regards,
rk
You can use ice spray on a metal mould. Ice the resin and than it goes off easy.
