Hi,
I have been testing infusion on some small parts and getting fairly good results. I now need to try and infuse some fibreglass onto a large sheet of plywood approximately 2000mm x 1000mm in size.
I would like to try and obtain the quickest infusion time possible and wondering if anyone has any advice on the location of the infusion lines and vacuum line please?
The ply is vacuumed against the glass to give a flat smooth finish, I leave the soric exposed at the edges to allow me to place the vacuum and infusion line in the bag. This also allows me to see the flow through the soric as a visual indication of the location the resin has travelled, very important as the ply sheet makes stops me from seeing the flow, the excess if then trimmed later.
I am unsure if I place the resin feeds on too many sides that some resin will reach the catch pot prematurely? Is this called race tracking? I was thinking of trying the place a resin line fully across side A, half way down to D (creating a 90 degree feed 1000mm x 1000mm) then putting the vacuum in the corner of side B & C (bottom right corner). Im still not sure this is the best method however?
Just wondering if anyone has any experience with this please or any advice?
Thanks very much :o Here’s my diagram:
