DualTwill…
1)How much vacuum are you pulling before you release the clamp on the resin inlet tube? What does your vacuum set up look like… picture please
2)Also on the bag… do you make your own bags or do you buy them? How do you seal all the openings in the bag?
3)Is there some type of film or material that goes between the bag and the dry lay up?
4)Do you use any spray adhesive to hold your cloth down and in place?
5)What brand and type of resin & hardener do you use and at what ratio (ie: 1.2% hardener)?
How long do you leave the lay up pulling vacuum for? 3, 4, 8, 12 hours?
How long do you wait to remove the part from the mold?
Lots of questions!:eek:
