I just thought of this and was wondering if its possible… I have an openface mold which is fairly flat, less thne 6" high. Instead of using the tape and sealing the bag around the perimeter of the mold, is is possible to just set it up like normal except skip the double sided tape and bagging material and just put the whole mold into a vacuum back? theoretically if the bag is much larger it should accommodate for the contours of the part no? then insert inlet/out into the bag and proceed…
if this is possible it will cut down cost dramatically since you will not need all the sealant tape, baggin material, and if there is a leak it will be easier to find since only one side of the bag will have an opening (once the bag is tested to be leak proof…
Thoughts?
