Yes, the layers are shown peeled away for clarity.
It was challenging (for me anyway) to create a 2D diagram that shows what’s going with the layers.
If you can imagine a flat piece of foam being used to make something like a bulkhead.
You would start by marking out the piece and then cutting it 4" oversized.
(that’s what you see on the left side of the diagram - actual part line +4")
Then, a 1" strip of epoxy and microballoons along the extended edge to seal the foam and create a better surface for the tacky tape.
This step may be omitted…? I got it from Henny:
(Scroll down to “Starboard Float - The Beginnings”)
Click on the image below that to launch the photo album. You’ll see the purple band across the outer edge of his float.
After that, the reinforcement fabric gets placed with a 1" oversize (for trimming).
Over that goes the peel ply - this goes all the way to the vacuum tubing (which can be cut into sections allowing you to clamp off vacuum from certain areas that may infuse faster than other areas).
Next goes the Perforated Release film which allows the consumables to be easily removed from the peel ply and also controls the resin flow.
(I’m still a bit fuzzy on this layer, but Herman swears by it and from what I can tell he really seems to know what he’s talking about)
There are quite a few threads on Release film. One of which is here:
That layer ends +1" over the fiber reinforcement.
On top of that is the Resin Distribution media which ends -2" from the cut line. This serves as a “brake zone” - Again, from the reading I’ve done so far, the brake zone gives some areas of the infusion a chance to catch up with the rest of the part and allow time for a complete infusion.
The Resin Inlet tubing has Flow media both under and above it and must be touching the Release Film and Peel Ply.
Depending on your resin viscosity, shop temperature and part complexity you will want to make sure your part will infuse completely with some time left over before the resin kicks.
For the epoxy I’m looking at, the working life is just over 80 minutes at 72 degrees - so I don’t want the resin flowing after about 30 minutes.
I plan on plumbing accordingly, (zones or whatever) to shoot for a 30 minute max infusion - this gives me a bit of breathing room in case something happens.
Mix and degass resin = 20 minutes
Shoot resin = 30 minutes
+20 minutes pot life remaining
In the end, what I’ve tried to do here is get something on paper that I can pin up on the wall to use as a static reference.
It won’t work for all parts, I understand that - but I’m hoping it does speed up a layout and make it easier and clearer to explain to others.
