Hi,
I have been asked to provide a few posts for a friend which has a timber core, I am however unsure if this if possible to produce without problems. I have attached a sample image of what I am trying to produce.
The mould consists of a simple ‘U’ shape however there is a piece of timber needed in the middle of the part which needs to remain in place. I was wondering if it would be possible to lay the mould up with gelcoat and include a breather as part of the fibreglass to allow this to be cast with the infusion?
Even if this was possible I am unsure where the infusion line would go for the resin?
I could also drill some holes in the timber to allow the resin to flow through if needed however I am still a little nervous as the timber core will not allow you to see the resin flow and wondered if I could get dry spots or inconsistent coverage?
I also considered casting the outer part first then bonding the core later. My issue with this is I am again unsure if I would achieve complete coverage of resin around the part?
I am really struggling to get my head around this and thought I would post this to see if anyone has achieved anything similar to this please?
Thanks very much.
