Hi Everybody
Asking for prices of resin impregnators shows that such equipment is really out of reach for non professionals.
I wonder if there are any diy plans out there. I wasnt succesful in my search.
On the other hand we could share our thought on how such a device could be build.
http://www.prosetepoxy.com/process_equipment.html
This link shows the basic principle of such a machine.
However there isnt any squegee with adjustable pressure to squezze out excess epoxy and keep a constant resin fiber ratio. Adjusting the tension between both rolls against each other works well enough?
In one homebuild impregnator I saw that they were synchronized with two rubber wheels at each end.
What material would be easiest to clean? Epoxy adheres to stainless steel.
What bearings would be ideal? Teflon gaskets?
The resin bath recipient out of galvanized iron or maybe out of some flexible plastic that could be wrinkled to get of dry epoxy (nylon teflon?)
Well for sure there are alot of details i am overseeing.
Any suggestions?
