quick question…I have always used poly resin and am making the switch to epoxy…I have a tin of polyester black dye that I use for the polyester,can I use this with epoxy resin??
thanks
Works fine
Essentially all pigments are a contamination, so the idea is that you don’t use much. But they all work with each other.
