Resin Consumption
Guys I was wonder how to mix proper amount of resin across infusion process?
I use 200grams twill, mesh , peel ply
Depends on the size of your part, and how many layers your using…
It also depends on what kind of mesh/ flow fabric you are using. How long are your inlet tubes etc.
You have to calculate/ trial or test all the resin consumption you have in your part.
Thats what I exactlly need for instance if Im going to build flat sheet 1meter x 1meter with 4 layers of 200grams carbon fiber twill how can I calcute possible resin consumption ?
There was a post recently, about this topic. Here the link http://www.compositescentral.com/showthread.php?t=7372&highlight=resin+calculation
