Resin choices
Guys,
I have been using Adtech 820, since this is the only clear infusion resin i can find…
Is there an alternative in the states?
I’m in Houston so the 60 min gel time on the Adtech is significantly reduced in the 90+ heat of my garage.
there is this resin on Ebay, Max 1618 but the 30 working time at 77f just isn’t feasible at temps over 90f.
Gurit T-Prime20 ULV is a nice resin system, low viscosity and almost clear
I’ve used 820 and like it. I do infusion and have switched to Huntsman 8601 resin. Infuses better and not as much degassing is needed because of its viscosity. As far as Houston temps I have a/c in my shops so I have better control.
