I’m about to repair a CF helmet…but I can’t think of a good way to go about this. As the picture shows, there is a crack in the topcoat, and the carbon has separated from the surrounding resin. This largely only affects the top composite layer, and the carbon itself is intact.
I need a way of injecting (or pulling) new epoxy into the damaged area, so that it will fill most of the voids that have opened up, and leave a fairly seamless repair.
Any ideas? Thanks in advance!
