I have been looking into casting molds using Ren DT 082 high density filler and epoxy, the goal is to have a mold that can be fairly easily yet extremely strong. The current molds we are using are polyester tooling resin, tooling resin and infusion. The biggest issue we are running into is molds deteriorating fairly quick. The parts are epoxy, molds are polyester, and a high mold cycle is required.
Would we be better off producing epoxy molds using the standard method of infusion, or would a cast mold using DT 082 and epoxy be significantly better?
