Removing wax
I was wondering what you guys use to remove wax from the molded parts(plugs).
If you need to…rubbing alcohol or paint thinner / mineral spirits…
But I only like to use semi perm. on my molds so I don’t have to wax the mold or de wax parts…
Already tried the rubbing alcohol and doesn’t work, I’ll check with the paint thinner…
i use wax and grease remover.works great does not leave any residue.
I second the wax and grease remover. We get it by the drums from my local auto body supply shop.
Wax and grease remover was the first to try but didn’t work for this type of wax
keep in mind that when using wax & grease remover you need two cloths. One to apply the solvent and one following immediately behind to absorb the wet solvent. Continually fold and replace the absorber cloth.
I’ve used frekote pmc. Works well with hard waxes with a bit of rubbing, no surface scuffing.
