releasing huntsman 8604 infusion resin
I’m having a tough time finding a suitable semi permanent release for huntsman 8604 infusion resin.
Anyone else happen to use this resin and successfully use a semi permanent release?
What did you try already? What is the mould surface? Did you also use a sealer?
I have never had anything stick to Ferrokote FS10 (sealer + release), but I am sure there are others.
The surface coat is huntsman rengel 1124.
I tried releasing with frekote 770-nc sealed with their fms sealer.
I also tried with some zyvax enviroshield, it didn’t work very well.
So I’ve been using wax until I find something that works.
After a part is cured, releasing is more difficult than it should be, and it seems that all the release has been removed from the mold surface.
A little more info on my process is i’m using this resin not with infusion but with light compression molding.
I’ve contacted the manufacturer without much of a solution.
