Ok, I’m going to take the time to post the different types of composites reinforcements here and sticky it. This will take some time and if anyone wnats to chip in, please do. Please ask any questions on the materials in a new thread, thank you.
Fiberglass:
Surfacing Veil Very thin, angel hair, chop strand material for the first layer after the gel coat to eliminate cloth print thru, to allow you to lay this layer up and wait until the next day to start the reinforcements layers. I also use it for spray booth filter pre-filter screening too! .010 or .020 thickness only. Not for use with Epoxies.
CSM Chop Strand Mat, the cheapest material, it is held together with a styrene binding agent which melts out with the use of PER, Epoxy is not used with this material, rated in OZ. per Square “Foot” (since the glass makers make this material, they rate it in weight per square foot), like 3/4 oz, 1 oz., 1 1/2 oz, 2 oz and 3 oz.
CSM Continous Strand Mat, long strand version of the chop strand type, the next cheapest material, it is held together with a styrene binding agent which melts out with the use of PER, Epoxy is not used with this material, rated in OZ. per Square “Foot” (since the glass makers make this material, they rate it in weight per square foot),like 3/4 oz, 1 oz., 1 1/2 oz, 2 oz and 3 oz.
Unidirectional The Fiberglass only runs in the 0 degree direction and with a felt backing that it is sewn too to keep it together.
Cloth Woven This is a bi-axis, only 2 directions Warp (length of the material coming off the roll, 0 degree) and Weft (width wise, 90 degree) woven fiberglass like the cloth item you are wearing, rated in OZ. per Square “YARD” (since this material is woven by textile companies, they rate it the same way as reg. cloth), can be thin as 3/4 oz to 20 oz tooling cloth.
There are several versions of this FG cloth like E-Glass (Econo fiberglass and flat strands) to a stronger S-Glass (a Trademark of Owens-Corning Fiberglass company) which has the strands twisted for more strength and better wicking of the resin into it too.
Woven Roving Just like the above cloth but tons heavier strands, does not bend easy, for mostly flat surfaces…
Aramid
[SIZE=2]Another name for Aramid, “Kevlar” made by DuPont. Usually bi-direction axis. Very hard to cut except with special hand shears or specialty tools. Tightly woven DRY Kevlar used for ballistic body armor protection to more open weave for better hold together than Carbon fiber (when a race car gets crash, the CF will expode into many peices but if there’s Kevlar in the laminate, then it will stay together more). Better to use Epoxy resin but you can also use PER too!
[i][b][SIZE=4]Carbon Fiber[SIZE=2]
TBC…
[/SIZE][/b][/i][SIZE=2]
[/SIZE][/SIZE][/SIZE]
