Recommendations for Cosmetic OOA Gurit Prepreg / SE 84LV
Similar to my other post , there is a canadian retailer that has Gurit SE 84LV. And again from what Ive read it’s not designed for cosmetic applications.
Any feedback on using SE 84LV and finish quality with OOA application?
Any advice on which Gurit prepregs may be a good fit for my needs?
Thanks.
I just wanted to ask the same question. Wondering if Gurit has a OOA prepreg that has a good cosmetic finish.
Gurit sprint?
Gurit SC 110, I´ve tried it once with the vacuum bagging method, it worked really nice.
Thanks for the reply!
Could you share your cure schedule, ramp, dwell times. Did you debulk when layering? Did you use sc110 just for the surface and something else for the rest of the stack? What was the mold surface? What did you use for peel ply, release film, etc and how?
Thanks!
Vacuum bagging method , 2 plies 12 k 400gsm twill, 2deg/ min ramp, 120 c as the tds said ( min)
Polished steel plate, chemlease 255 release agent, release ply non perforated, breather. Nice surface!
