I searched the forum and couldn’t find this exact issue- apologies if it’s been discussed previously…
Poly and fiberglass mold with tooling gelcoat, wet sanded, polished, and buffed to a mirror finish, clean mold, seal mold, and finally treated with a semi perm. (not that it should matter, but this tool in the pic is for a vehicle hood)
After infusion, I’m getting a haziness in spots (on the tool and transferring into the part) that looks like slight alligatoring, (but more like a rough patch of graininess). You cannot physically feel any kind of roughness in the tool’s surface, just a haze where the mold is no longer glossy. This only happens when using polyester resin and a polyester gelcoat as an IMC. (weather I infuse or spray with chopper gun) The part still releases effortlessly- it’s just the mold get’s a larger, grainy, hazy section somewhere on the tool’s gelcoat after each part that is removed from the tool. I can’t keep polishing and reapplying release between parts. It’s just not productive.
If I use Duratec clear topcoat or sunshield as an IMC, laying up carbon specifically, and infuse with epoxy- the tool is perfect.
I don’t want to name the company for the semi perm as of yet because they have been super helpful and have asked me to try EVERYTHING… and I have done everything I know to do. They have gone so far as to send me samples of everything they offer. It still happens no matter what. Also, the few distributors that I deal with are clueless as well.
The picture is hard to see, but yes- that grainy texture is what is happening somehow and again, you physically can’t feel it.
Obviously, it’s something with polyester on the tooling gelcoat having a reaction, but why?
A friend of mine uses the exact same processes as me with the exact same release and he doesn’t have this issue when making poly parts.
Suggestions?
