I have been reading on this forum and another and also seeing the tutorials and want to see if I understand it all correctly to do my project. I used t0 work for a body shop doing mild body work so im familiar with bondo, fiberglassing, painting, except I have never done anything custom before, but Im all about learning new things to further my hoobie of modifying cars.
I want to make this CSL lip (see pic 1,2) out of fiberglass and have a part of it CF (see pic 2,3) which then I want to mold it into the trunk. This is what Im planning on doing, correct me if im wrong.
I am only going to be making one of these pieces so I will not be needing a mold. My plan is to use polyurethane foam that comes in blocks and shape it then overlay fiberglass on it and then CF.
Im not sure if I should use 2 resin types or one since I could use polyester resin for the fiberglass since its cheaper and then use the Surfboard Resin (not sure what it is exactly) because its clear for the CF or could I just use the polyester for all of it. I want the CF to show up very clear. Please advise here.
Heres the step by step. Feel free to critque or give suggestions.
apply blue tape on the trunk so I wont ruin the paint while shaping the foam incase I mess up.
apply some kind of adhesive to hold the foam blocks down to to trunk. (not sure which kind, ANY SUGGESTIONS?)
apply polyurethane expandable foam in the cracks of the blocks.
shape the foam to spec but just slightly smaller than the original part because 1 layer of fiber glass will be layed on top of it.
THis step im not sure which way to go (SOME HELP HERE). Once the lip is formed, is there supposed to be a filler or primer that is supposed to go on the foam prior laying the 1st layer of fiberglass down or could I just lay the fiberglass directly on the foam with resin. Wouldnt the resin go into or melt the foam if I dont fill or primer the foam. Please advise. (Also consider my next step)
Ok so after the first layer of fiberglass is put on, I was planning to put 2 more layers but on the inside of the 1st layer, meaning that I would have to rip out all of the foam somehow and smoothing out the inside and then applying the next 2 layers. Is this a good way to go about it or should I just continue adding the 2 layers on top of the first. Although this way I am scared that the shape will not be exact…
Trim fiberglass just like in pic 1.
Now is when I plan to make the “MILK SHAKE”, part bondo, part resin and resin hardner, to smooth out the fiberglass. Or is there a better way to smooth out the top layer of fiberglass.
After I smooth out the fiberglass, I will then cut a piece of CF and wrap the lip in CF going through the CF routine. Put resin down, wait till tacky, then lay the CF. Then 2 layers of resin and sand with 380 wet then as many more layers of resin as needed and sand, wet sand going finer to finer 2000 grit, and buff to a shinny glass like finish. Although im afraid this might cause air bubbles.
Now if everything turned out ok and is smooth, I plan on taking off the tape and adhering the lip to the trunk and molding it in.
Taping off the CF that I want showing, then painting the thing and clear coating it.
I look forward to everyones help. Thanks.
