I’m currently investing on equipment so it seems to be the right time and right place to ask.
My first attempt couldnt be easier; I’m planning to make a 3mm to 4mm thick carbon fiber plate, about the size of an A3 print paper, then cut it with my dremel 300 into smaller R/C parts. My second attempt will be to create a mold to make the same R/C’s chassis bathtub, about 2mm to 3mm thick.
The most affordable carbon fiber sheet I’ve found so far here in Brasil is a 2/2 twill, 3k, 0,2Kg/m2. I’m also planning on using a higher heat resistance epoxi resin.
A few questions:
1- How many layers of carbon fiber do I have to use in order to achive those desired thickness?
2- Is it possible to alternate layers of carbon fiber and fiberglass? Would that reduce significantly the final product performance?
3- At my first attempt, I’m thinking about trying the resin hand laying technique, cause its my first contact ever with composites and also because I can’t afford all the vacuum related equipment plus carbon textile all at once. Would this technique also reduce the final product’s performance too much?
To build the chassis bathtube and planning on trying a vacuum bagging or infusion, following one of the great tutorials found here at composite central.
Cheers
