Hi all,
Here are few of my creations, I’ll post a few up each day.
What happened to my first post, all my pictures have gone?
OK I’ll try again.
Some more of my parts
got to say ur parts are wet dreams for carbonlovers
PS. Little tip when uploading ur pics. U can reduce ur pics using http://www.picresize.com/
u can reduce ur pics online. i reduce to mine upto 75% and they fit perfect on the forum windows and download is very quick.
thanks for that, I like high res pictures you can see a lot more detail
That’s the most beautiful work i’ve seen on this forum. Damm that looks really great.
Thanks for the compliment
look great! what are you using, infusion or prepreg? What brands?
Autoclave prepreg.
Do you clear coat after the parts are demolded or go with an in mold coating?
Whos prepreg do you use?
Off the mould unless I’m putting decals on the part like a fuel tank or side panel.
What weight fabrics do you use and how thick do you make the parts?
2x 200g 2x2
1x 190g Kevlar
1x 1mm Nomex
1x 200g 2x2
Or
2x 200g 2x2
1x 190g Kevlar
1X 200g 2x2
If using open unpainted finish always go 2x carbon first or you will see the Kevlar through the cross toe.
