Three pairs of frame guards destined for the IOM TT , made from carbon and diolen with epoxy resin and post cured. Moulds and final components by carbonfibreworks@aol.com weight ? 90 grams each
( with two layers of 2k clear ) produced using infusion.
Hi would you mind sharing your post curing process. this is one area i’m failing to get my head around, i’m trying to build a curing oven but not sure what heat source to use as well as how to control it, would a normal stove oven do the trick?
thanks
HI Double
To start with the temp required should be available from your resin provider, yes you could use a domestic oven but be aware the temp on your control panel may not be accurate and would you wish to cook food on it later ? I have made an oven from a catering stainless fridge/cooler, the heat source is an issue and I have used a fan heater in the past and a temp gauge in the oven with a remote read out.
Regards Chris
