Quick tip, think it would work?
So someone who i told them about my delamination problem in the post, said instead of using ANY adhesive… to use some uncured EPOXY! very VERY little to hold it in place. would that work you think?
thoughts…
I doubt it as Epoxy needs the chemical reaction to cure…PER only needs heat from chemical reaction or a hot batch applied to a under cured layer.
Epoxy resin doesn’t produce the necessary heat to cure it…
and the other thing, since the epoxy is a very low vis. i doubt it will work since the glass would absorb the epoxy =\
Are you still having really bad delamination problems?
YES! =(
i just got in a diff type of resin. im going to see if it eats away the super 77… its kinda upsetting really, as im using REALLY small amounts of 77
