I am looking for some infusable VER that is kicked by UV and also a gel coat that is UV kicked too.
Let me know what your thoughts are on using this
I have not heard of one. I know of many epoxies that are uv curable…they are called sterolithography resin and you don’t want to go there…whew talk about expensive.
The beauty salons use an acrylic that is uv curable…I wonder what it retails for in larger batches?
I had a gallon or two of UV curing PER resin but since my class is at night…I think I gave 1 to EMI and may have 1 left.
It came from RevChem but not sure if it VIP able or the viscius of it…
I just wonder if it would cure thru the vacuum bagging, peel ply and breather???
Maybe I / we can try it during spring break at the end of March as there isn’t classes but I’ll be down there probally more than seeing my wife…J/k…
I called EMI and he said he used that gallon and it worked great but he does not know anywhere to get the VER of it.
