canyon (or all),
I am currently trying to understand this whole lamination theory deal, so I am working some problems in a book I have. Instead of using the books strength and modulus numbers, I decided to use numbers from a prepreg manufacturer I may be getting some unidirectional material from. The question I am having is that I am not sure what to use as my shear stress term. I am given the short beam shear strength in the 0 degree direction and the 90 degree direction as per the ASTM D-2344 standard test. I thought that there was a certain congruency in shear stresses though, so only one value was used. Which one do I use, the 0 degree direction? or the 90 degree direction? or the lowest of the two? Or am I off on my theory and I actually need to use both of these values?
thanks,
Fleisch
