Hello everyone,
I have read a lot regarding different techniques and “how-to”'s on the internet. But I do still sit om my chair with some questions that seems pretty big for me. I will first tell a bit about the project, and then ask the questions below.
In my bachelor thesis this spring I’d like to engineer, build and test a Under-Water Scooter(DPV - Diver’s Propulsion Vehicle). Built to whitstand the pressure of 100m depth(approximately 10bars) and a lot of rough handling. It will consist mainly of two plugs, and one tube as a pressure hull. Plus one large cowl for protecting the propeller/diver. The inside of the tube must be very good, because of O-ring sealings. So I thought to use an old Dive cylinder as a mould. I also thought it’s smart to put it in the lathe and make a fine cut to make the surface as good as possible. Please look at the attached photos of some really bad CAD drawings(just for me to think out the solutions to the real CAD drawing and model).
Questions:
#1 How would you prepeare a mould that must be circular(ID:195-210mm) and have a length of approximately 4-500mm.
#2.0 Would you use prepreg, vacuum infusion or shrink tape?
#2.1 In case of prepreg: Is it then possible to implement some kevlar or CF/Kevlar to improve impact resistance of something that can get some abuse.
#2.2 In case of vacuum infusion or shrink tape: How can I start to lay the CF and kevlar and still get it tight enough, so it doesn’t buckle under vacuum or shrink? This is what I’m most worried about.
#3 Is it anything “bad” to use an excessive amount of woven CF rather than the right amount of uni-directional CF? I need a good safety factor.
#4 Will it actually help to implement some layers of kevlar to the construction to improve toughness?
#5 How many layers would you approximately use to get a wall thickness of 5mm? And would this be very over-kill?
#6 (sorry guys, many questions) Will it have any purpose to use uni-directional tape and build some ribs on the outer layer? To improve both stiffness and durability.
Thanks in advance for the answers! I promise that I will keep you guys updated. I just got material samples from Easy-composites, and I will make an experimental hull for a dive torch or something to get used to the materials.
Best regards,
navigas
(sorry for Caps)
