I am trying to skin some very simple shaped interior car parts, but the carbon does need to wrap around the edges a bit.
I first tried skinning without a vacuum bag, but the fiber lifted from the edges thus making the parts not usable.
So I got materials to do this with a vacuum bag but I’m having some troubles and I am looking for help.
In my first vacuum bagging attempt I used a perforated release film over the part, but when it cured the epoxy dimples caused the surface finish to look pretty poor. I sanded too deep and ruined the twill.
In the second attempt, I used standard release film. The problem is that the film itself wrinkles easily, and any wrinkles translate to the finish. Also, this process seemed to leave more trapped air, and thus bubbles in the finish. So this didn’t work.
Lastly, the vacuum bagging tends to cause creasing around the edge of the part, which leaves an uneven epoxy finish.
Any suggestions on how to get a better surface finish? Should I just use peel ply instead? I thought that may leave a worse surface finish, but I’ve yet to try it.
