Apologies in advance for the length of the thread!
As with my vacuum bagging thread, the purpose of this is to help me sort out pricing.
The plan for my oven is to construct it out of the rigid, foil back insulation foam using either 50mm or 60mm thickness. Internal size wise - would guess around about 1m x 1m x 1m. May make it bigger once the foam sheets get bought (they’re 2400mm x 1200mm in size). Thinking of getting the temps up to 100-130 deg C.
Seeing as the foam is rigid, the idea was to make it self supporting - i.e not making an external wood or metal frame.
As for the individual parts;
There are several heating elements I found, but don’t have a clue which would be best?
http://uk.rs-online.com/web/p/cabinet-enclosure-heaters/7166100/
http://uk.rs-online.com/web/p/cabinet-enclosure-heaters/0603328/
http://uk.rs-online.com/web/p/ceramic-heating-elements/3762688/
http://uk.rs-online.com/web/p/ceramic-heating-elements/7241772/
http://uk.rs-online.com/web/p/air-heaters/3742319/
http://uk.rs-online.com/web/p/air-heaters/6151637/
Temp controller;
Is a PID controller the only one to get - as opposed to an on/off version?
http://www.cdautomation.co.uk/temperature-controllers/setpoint-profilers/atr620/
http://uk.rs-online.com/web/p/pid-temperature-controllers/0461212/
Fan;
Is a fan necessary? If so, what sort do I need that’ll survive up to 130 deg C temps?
Solid state relay;
REALLY clueless regarding which one I’d need.
Is that everything I’d need? I really appreciate people taking the time to read my thread
Thanks.
