My process is currently 100% wet layup using epoxy resins, two sided closed mold using a high pressure bladder. There is a fair amount of detail, and the use of any kind of of breather material is difficult or impossible to remove from the finished part. Current resin is Resin Research 2000CE and various speed hardeners.
I would like to attempt a few runs using DIY prepreg, which would allow ample time to trim and work with the laninate before it is closed and cured. I understand there are many ways to approach this technique, which leads me to the question(s).
Method 1) reinforcement material pre-wet out using thermo-set resins. This would allow longer storage, ease of cutting shapes from templates, but is less cost effective and difficult to source thermo-set resins.
Method 2) reinforcement material pre-wet using standard epoxy resin with extra slow hardener and placed in a freezer for a short period, removed and cut from template and immediately cycled into the mold.
Method 3) using commercially available prepreg material. This would be the least cost effective method, and I have less control over resin ratios.
The current molds are capable of approximately 250 degrees f, but many prepregs and thermo-set resins require greater curing temps. Any input is greatly appreciated.
