I have begun manufacturing of a composite rifle stock for what will soon be a larger scale production. They are currently being laid up in one piece, a bladder inserted and inflated to approximately 20 lbs. Material is epoxy and E glass, but there is still a decent amount of finish work required in the flashing or partition area I would like to try to reduce. The stocks are produced as one part for strength, not two parts fused.
I have been struggling with a few things; first is the bladder material to use. Currently we are using SL-800 fused together, a rubber plug as a stop in the butt of the stock and the bladder inflated after layup. I have been able to get about 5-6 runs out of the bladder, not bad but not good enough for production. I think there is a fair amount of excess resin that can be removed with a bladder capable of higher pressure, resulting in a stronger and lighter part. I am seeking a better material or method for the bladder.
The second concern is the life of the mold, which seems to start to fail in areas after 10-15 part cycles. The original molds as pictured are a 2 part mold made of polyester resin and tooling gel coat, the partition line isn’t straight, but that is not a issue. We are using a quality semi permanent sealer and release agent, and applying additional release after 3-5 parts. I am considering trying a semi rigid polyurethane mold inserted in a rigid fiberglass mold in hopes to get a longer mold life.
Last question; I want to produce carbon fiber and Kevlar versions of this stock, and wondering what would be the best way to make the partition look good, since it will be a cosmetic part. Currently, the production parts are made by tinting the epoxy gel coat, so little care needs to be taken during layup to ensure the material is straight.
Any input would be appreciated
