If its partall no2 then it contains no silicone. That is why it does not fish eye. If you are getting fisheye’s on your mould surface then you have a contaminant on the mould surface. I’m hearing it now. Of course he has, that is stating the obvious. We’re did it come from, did the polish you used on the mould contain silicone? If it did then eliminate all silicone based polishes out of your workshop not a great thing to have in an FRP workshop. Always use non silicone based polishes or compounds. Once you have contaminated your workshop with silicone it is very hard to remove from the environment you are working in.
The other is what waxes are you using? Most waxes have a content of silicone in them.
Meguiars MGH8, Formula 5, etc.
This isn’t a problem as long as you apply and remove properly. Some are easier to remove and others are harder. Try a few of them, so you can make the choice on what suits you best. Always allow waxes to dry on the surface prior to removal. Always, once you have removed the wax buff the surface by hand with a new rag or microfibre cloth to a shine. Always cycle your rags. Meaning, dispose of the used rags, and always cycle your rags between each coat. The rag you use to buff the surface to a shine, use on the next coat to remove the dried wax. Then this rag is disposed of and and then so on. What is not a bad idea, is to seal your mould prior to waxing with solvent based or water based sealer, then wax your moulds. You will find you wont have to apply as many labour intensive coats of wax. Eliminate contaminants from your air supply as well. Oil and water traps are essential if you are using air to blow down moulds or spraying.
By applying the wax properly and removing properly you eliminate wax build up. It is a painful exercise removing wax build up from mould surfaces, and even more difficult removing it from the part you have made from the mould that has the wax build up. Do not over wax as well. Herman is right, if you have done the prep work PVA’s are a band aid effect, not a solution.
